Outbound dial peer not working
Jul 23rd, 2007
Here is my dial peer config
dial-peer voice 5 pots
description T1-CAS
service mgcpapp
port 0/2/0:1
dial-peer voice 6 voip
destination-pattern ....
session target ipv4:
dtmf-relay h245-alphanumeric
a debug shows that I am matching the inbound dial peer 5, but then I get a dial tone and fast busy on the phone. Any thoughts
thanks for your help
shikamarunara Mon, 07/23/2007 - 09:16
Is this supposed to be an H323 dial peer? What are you trying to accomplish?
balitewiczp Mon, 07/23/2007 - 09:27
No, it is an MGCP GW servicing 15 DID's with a 5 channel T1-CAS line.
shikamarunara Mon, 07/23/2007 - 09:39
You should not be manually configuring dial peers on an MGCP gateway unless you're setting up SRST. In fact, that's kind of the point of using MGCP to begin with; it configures dial peers for you when you set up the gateway in CallManager. Your MGCP dial peer will literally look like this when CM sets it up for you;
dial-peer voice 999100 pots
application mgcpapp
port 1/0/0
dial-peer voice 999101 pots
application mgcpapp
port 1/0/1
Do NOT try to set up the above example manually, it will not work. Brush up on MGCP, it's easier than you're letting it be.
