Help configuring 2 871 routers
Jul 23rd, 2007
I'm trying to configure 2 871 routers but can't get the vlan ports to send anything out the Wan port.
The Wan Ports are conected to a 2Mbps Metro-wan link that connects 2 sites and the switch ports are connected to our local lan.
Attached is the output from sh run
Thank you for any help
purohit_810 Fri, 07/27/2007 - 18:44
We are not able to read your attachmnt
Please attach fil againa and let know.
- Dharmesh
nikolay-shopik Sat, 07/28/2007 - 04:46
just use other editor than notepad, which can handle both windows and unix style CR/LF.
nikolay-shopik Sat, 07/28/2007 - 04:43
First of all your access-list 100 permit ip any any in end so you better remove other strings before it's just wasting of router cpu cycles.
Vlan interface
ip address
from dhcp pool are not same machines behind router will try to send packets to not as suppose to be.
