POE on the 3560
royalblues Mon, 07/23/2007 - 14:18
  • Green, 3000 points or more
Std 3560 & 3750 can power up phones on all the 48 ports provided the phones are class 2 category(7.7W)
if you want 803.af on all the 48 ports, you need to procure 3560-E or the 3750-E which support 15.5w/port on all 48 ports simultaneously
HTH, rate if it does
Narayan
Thanks Narayan, but I have no intention of paying that much money just to get a good switch with POE to the edge.
After 10 years I am now off of the Cisco bandwagon. Nortel has a stackable switch with full POE for half the price. Cisco is as bad as Microsoft now-a-days. I'm done recommending their gear.
