Duplicated IP Address
omarept
Hi List,
Currently, I have a problem with some PPPoE accounts. I configured a Cisco3640 as NAS, and ACS as AAA for PPPoE users authentication. The users that use only one VLAN working fine. However, I have users that uses the same VLAN (different accounts) and the Cisco AAA ACS provide the same IP address:
Vi13 20761 PPPoE 00:00:07 200.110.46.18
Vi14 10080 PPPoE 00:00:00 200.110.46.18
The VLAN (Subinterface) configuration is:
interface FastEthernet0/0.6
encapsulation dot1Q 6
ip access-group control-full in
no ip redirects
no ip proxy-arp
rate-limit input access-group 140 136000 25500 25500 conform-action set-prec-transmit 5 exceed-action drop
rate-limit input 72000 24000 24000 conform-action transmit exceed-action drop
rate-limit output access-group 140 136000 25500 25500 conform-action set-prec-transmit 5 exceed-action drop
rate-limit output 72000 24000 24000 conform-action transmit exceed-action drop
pppoe enable
pppoe max-sessions 7
no cdp enable
arp timeout 300
end
Please any suggestion for resolve that issue?
Thanks in advanced.
Rgds.
Premdeep Banga
Level 7
Level 7
I am assuming that for correct operation of IP address assignment you have configured accounting as well.
If that?s he case, they you might consider taking a look at,
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCeh37907
CSCeh37907 : Duplicate IP assignment due to accounting packets reordering.
Prem
6dchovatia
deleted - posted in a wrong thread sorry. can't find an option to delete.
