ASA SSL VPN CLIENT without browser
Jul 23rd, 2007
I know the new AnyConnect VPN client allows you to establish SSL VPN sessions to ASA 8 without opening a browser
Can I get such functionality with ASA 7? I downloaded the SSL VPN client from software center ( but this only installs the package into the computer but initiation of SSL VPN sessions still needs to be done by the browser
Thank you
sbilgi Fri, 07/27/2007 - 13:32
Probably, the feature start before login might be supported in the Cisco SSL VPN client. If this feature is supported, then you need to enable it and your requirement will be fulfiled.
ishah Wed, 08/08/2007 - 15:54
Start before login is not support on the SSL SVC client, only the Anyconnect and IPSec clients.
