5.0(4) to 5.1 Upgrade
Jul 23rd, 2007
Guys just a small question on this. im going to upgrade to 5.1 and just wanted to be sure of the procedure. it looks fairly simple. the question is once i complete this upgrade and switch the versions, will all exisitng configurations will be copied onto the new 5.1?. is it as simple as switch the version and thats it?'
Overall Rating: 4.5 (2 ratings)
thisisshanky Mon, 07/23/2007 - 20:23
to explain a little more in depth, with CM 5.x, while your system is currently running on one partition, the second partition is used to perform the upgrade and once the upg is complete, now u have two versions in the system, which you can switch back and forth (same information in the database, phone counts, users etc..). Before or after the upgrade, if i remember right, it asks you if you want to reboot the system in new version without having to switch manually.
PS: please remember to rate posts!
