Incoming Call issue
Answered Question
Jul 23rd, 2007
Hi All,
We have a cisco 2801 router that currently has our ISDN service connected to it. This ISDN service has a 100 incoming number range associated with it. It now also has 2 additional incoming numbers that are completely outside of this range. I need to somehow configure the router to accept the calls coming from the additional 2 incoming numbers. Currently, when someone calls one of these 2 numbers, the call will successfully go through the first time, but then when a second call tries to go through (after the first call has ended)the caller receives a busy signal. Speaking to my Telco, they say it is a SIP Translation issue! I have no idea where to start. Can anyone provide me with some help?! I have MSN Messenger if it helps to try and get this sorted out as soon as possible.
I have attached our config for everyone to look at. As you can see the 100 range is working fine and is defined by the 02611780.. i have 2 other numbers to add which are 0262251234 and 0262254321 (completely out of the range and are not sequential)
Your help is greatly appreciated! Any questions, please just ask!
Correct Answer by gogasca about 9 years 7 months ago
dial-peer voice 3 voip is the one you are using for 02611780..
Try to add the following:
dial-peer voice 6 voip
translation-profile outgoing calling
destination-pattern 62251234
voice-class codec 1
max-redirects 10
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
dial-peer voice 7 voip
destination-pattern 0262254321
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
Overall Rating: 5 (1 ratings)
Correct Answer
gogasca Mon, 07/23/2007 - 23:04
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
pjscott13 Wed, 07/25/2007 - 16:36
Thankyou! That was relatively easy! With no problems at all. Thanks!
