Jon Marshall Mon, 07/23/2007 - 22:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Yes you can use aggregate-port learner and this is the default on most switches. Aggregate-port learner can use any of the physical interfaces within the etherchannel to send the traffic ie. it doesn't care which physical interface it came in on.
Jon
Pavel Bykov Wed, 07/25/2007 - 22:13
  • Silver, 250 points or more
If you use normal etherchannel, you can use the following command to choose balancing technique:
(config)# port-channel load-balance {src-mac | dst-mac | src-dst-mac | src-ip | dst-ip | src-dst-ip | src-port | dst-port | src-dst-port}
Depending on the platform , not all options have to be present.
Related document:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/swethchl.html#wp1040929
pccthailand Thu, 07/26/2007 - 00:20
Hi Jon
if i select aggregate port-learner methods for balance traffic , the switch will not forward or recieve the frame on the same physical link ? if i would like to fwd or rcv on the same physical, i should select physical port-learner ?
thanks
Jon Marshall Thu, 07/26/2007 - 00:38
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
With aggregate port-learner you don't care which physical link in the eherchannel the switch uses.
If you would like to fwd and rcv on same interface yes you can look at physical port-learner.
You don't say which switch you are using. For example you can influence which port is used in an etherchannel on a 3550 by using the pagp port-priority command. I've included a link to the 3550 config guide which does a good job of explaining the difference.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_4_ea1/configuration/guide/swethchl.html
One thing to be aware of. Etherchannel is designed to load balance traffic across a number of physical links. If you start specifying which port can send which traffic you can go too far with this and kind of negate the whole idea of using an etherchannel.
Jon
