07-23-2007 11:52 PM - edited 03-05-2019 05:27 PM
Hi netpros,
Can you please help me understanding what could be causing a port on the etherchannel to appear as D when issuing the command show ether summ. NOTE: I have checked the configuration on both ends and it is exactly the same and the ports are physically connected.
access-1#show ether summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SU) - Gi1/1(P) Gi1/2(D)
Your help is much appreciated !!!
07-24-2007 12:03 AM
Can you post the configs?
There are few things need to be identical on both sides when configuring etherchannel (same vlan, speed, duplex, if trunk same allowed vlans etc.)
Take a look to this link:
Hope it helps, rate if does
Kriszti?n
07-24-2007 02:53 AM
Hi .. thanks for your comments .. I have read that document before already. As mentioned in my original post the configuration on BOTH sides of the Etherchannel is exactly the same.
07-24-2007 02:57 AM
Have you enabled negotiation (pagp or lacp) or just turned on the channel group?
Is the disabled port in err disabled?
Did you get any syslog message?
Krisztian
