Lost call on 7920
Jul 24th, 2007
this is the situation in our deployment:
a 7920 phone is configured with line xxxx. Same line xxxx is shared on 7940 phone.
Sometimes a call, routed to line xxxx, ring on 7940 but the 7920 is not alerted at all. So we have only a missed call signaling on 7940 and the call is lost. The 7920 is always in roaming...
Any hint?
migilles Tue, 07/24/2007 - 11:09
  • Cisco Employee,
For 7920, would ensure you are using 3.02.
Also for AP not sure if you are using autonomous or lightweight controller.
If lightweight controller and pre-4.0.217.0, was an issue where 7920 connection to CallManager could get reset as the packets could get aged out within a 1 second period.
The workaround was to set the 802.1p tag for platinum to 7 vs 6. Would suggest to upgrade if possible though.
Also the 7920 sleeps every 2 seconds and doesn't use DTIM to check for queued packets, so could potentially be up to a 2 second delay. Would need to ensure proxy ARP is enabled on the AP with the 7920.
Send more info about your network.
