Mass interface configuration
Jon Marshall Tue, 07/24/2007 - 01:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Peter
switch(config)# interface range fa2/1 - 10
switch(config-if-range)# switchport access vlan 1
Jon
ankbhasi Tue, 07/24/2007 - 07:15
  • Cisco Employee,
Hi Peter,
In addition to Jon's post even if your port range is discontigous you can configure them at one go
Switch(config)#int range gig1/0/2,gig1/0/8,gig1/0/24
Switch(config-if-range)#switchport mode access
Switch(config-if-range)#switchport access vlan 1
Ankur
*Pls rate all helpfull post
jdarrish Tue, 07/24/2007 - 11:58
I think you're looking for the 'range' command after 'interface':
For instance to set ports 2/1 through 10 to vlan 55, run the following
switch(config)# interface range fa 2/1 - 10
switch(config-if-range)# switchport mode access
switch(config-if-range)# switchport access vlan 55
