Unable to play prompt to outbound call
Jul 24th, 2007
I am using IPCX 4.0(4)SR01_Build029 (premium version).
I created a script with the following behavior :
- My internal users dial extension 6306
- the script accepts the call and asked for a number to dial with a play prompt step.
- the script gathers the digits and dial out a new call using Place call step.
- Then I try to notify my external called party using a play prompt step. it fails and here is my problem.
Scipt debugs tell : com.cisco.dialog.PlayPromptDialog is not supported.
I seems that I can play prompt to the original triggered contact (original called party) but not to a new called party created by the script.
Is it true ?
Gergely Szabo Fri, 07/27/2007 - 08:58
yes, the PlayPrompt prompt will be played to the original contact that triggered the script.
A workaround may be to use to conference the triggering contact and the placeCalled contact together then use the PlayPrompt step.
nikolaas.noyez@... Tue, 07/31/2007 - 05:26
The Place Call step results in a Contact ( variable that you have created ). In the Play prompt Step, you need to specify this contact instead of triggering contact. -> the prompt will be played to the external party
question : how do you set up this conference ?
I can't join the new contact and the triggering contact in a conference ?
I've made my own workaround : I dial the script, the script dials out + hangs up on me.. once connected, the script redirects the new contact to the original calling number, which is my number --> all cost go to the company
