How stp BPDU communicate between cst,pvst and mst spanning tree mode
Jul 24th, 2007
i am facing pvid inconsistancy and type inconsistancy problem in my network.
network connectivity
Sw1----------------Sw2--------------Sw3
sw1 is cisco siwtch(spanning tree mode pvst+)
sw2 is extreme switch(spanning tree mode is CST,it is work on cst only)
Sw3 is cisco (spanning tree mode pvst+)
Francois Tallet Tue, 07/24/2007 - 08:44
  • Gold, 750 points or more
Make sure you are using the same native vlan on the link between Sw1/Sw2 and Sw2/Sw3.
Else, run MST on sw1 and sw3.
Francois
Francois Tallet Tue, 07/24/2007 - 08:51
Oh, my previous email was for the pvid inconsistency. Make also sure that you're trunking on those two links;-)
If this still does not help, please, tell us exactly what inconsistency message you get, on which port, and the trunking configuration of the different ports involved.
F.
