Radius and cisco 3550
Jul 24th, 2007
i want to insert 20 switch of my network under authentication trought RADIUS SERVER (IAS , windows 2003 server)
ON windows 2003 - IAS
I've create the object with the ip of the switch in the folder "Client RADIUS" and i created the REMOTE Access Policy and in the metodh oh authentication i have selected MD5-challenged.
On my switch, i inserted this command:
aaa new-model
aaa authorization network default group radius none
server-radius host auth 1812 acc 1813
server-radius key cisco
i want exclude the console connection with a radius authentication.
have you a link that explain this?
or can you posted a configuration of switch that have the authentication at the radius?
Thanks for your help
simonstoll Tue, 07/24/2007 - 02:28
That should work for you:
aaa new-model
aaa group server radius rad_admin
server auth-port 1812 acct-port 1813
aaa authentication login default group rad_admin
aaa authentication login Console line
aaa authorization exec default group rad_admin
radius-server host auth-port 1812 acct-port 1813 key XXXXXXXXXXXXXXXXX
line con 0
login authentication Console
You have to check wetherever your server works on TCP 1812/1813 or 1645/1646.
With this config you can also login directly to enable mode, if you supply the Radius Atribute
009/001 cisco av-Pair "shell:priv-lvl=15"
Hope that helps (if it does, don't forget to rate)
