IPS Log geneate in VMS
Jul 24th, 2007
I have VMS which management and monitoring IPS. 3 IPS added in VMS. a lot of log generate from IPS to VMS. I want to reduce the log. so how I can do
that.
thanks
Biplob
Overall Rating: 5 (1 ratings)
jreekers Tue, 07/24/2007 - 20:50
  • Cisco Employee,
NMSROOT/bin/logrot.pl can do this. See the online documentation on how to configure it, but essentially you run NMSROOT/bin/perl NMSROOT/bin/logrot.pl -c and follow the menu prompts.
Good Luck,
-Joe R.
iqbalkhan Tue, 07/24/2007 - 23:37
no clear. I want to know any command in IPS which reduce log generate. like IPS generate only mid and high level alert meesage to the VMS.
thanks
Biplob
