Need urgent Answer about VMS
Jul 24th, 2007
HI
I have install VMS in sun solaries. when I first install VMS I just install management center for IPS sensor. now I need management Pix firewall. so IF i install 2 of 4 cd which contain management cd and check Pix firwall then after install any previous IPS sensor which is added before delete from the management center ?. pls help with the answer.
thanks
Biplob
David Stanford Wed, 07/25/2007 - 06:03
  • Cisco Employee,
You might want to post this under a security forum
