Problem with VLAN Going in shutdown mode after power On
Jul 24th, 2007
I have one cisco switch series 3500 and I am facing the problem with the VLAN.
Once I configured it and saved all the config,and after that If I power off the switch and then again power on the switch ..its VLAN goes in shut down mode.I have rechecked it again all teh config and again made the VLAN no shut..and when Once again I did the same thing power Off and On the VLAN goes again in shut down mode..>can any one please help. It SW version is 12.0(5)WC13.
Jon Marshall Tue, 07/24/2007 - 03:20
Can you post config of switch.
Is this switch acting as a layer 2 or layer 3 switch ?
Surj1tKumar Tue, 07/24/2007 - 03:34
IT is acting as layer 2.
kindly understand the things from the attached mail ..this is the switch swutc1..
waiting for ur response ASAP..JON
Surj1tKumar Tue, 07/24/2007 - 03:27
It is UP but..see if anytime the power goes off the VLAN goes in shutdown..and again through console we have to log in and we have to make it shut..and it starts working..but again if we power off the switch again it goes in shutdown..then again we have to take to console and make it up
lordthyag Tue, 07/24/2007 - 04:07
Looking at the configuration file u have attached, i c a shutdown command at the end of the interface configuration
ur config:
interface VLAN2
ip address
no ip directed-broadcast
no ip route-cache
Do a no shutdown to the vlan interface and then copy the config to startup config ... and then reboot ur switch and check ...
hope this helps u ....
Surj1tKumar Tue, 07/24/2007 - 04:13
as the switch is at customer end I will try this once i go ther and will let you know..
lets see if this works..
