NAC/CCA Configuration Verification: OOB + Virtual Gateway (L2)
edwardwaithaka
I am currently configuring a NAC deployment based on Out-of-Bound OOB with Virtual gateway. Can someone please verify my configs below:
Core Switch:
VLAN DB:
vlan 10
name VLAN_DEPT1
vlan 11
name VLAN_DEPT2
vlan 20
name VLAN_DEPT3
vlan 26
name VLAN_DEPT4
vlan 27
name VLAN_DEPT5
vlan 28
name VLAN_DEPT6
vlan 29
name VLAN_DEPT7
vlan 30
name VLAN_DEPT8
vlan 32
name VLAN_DEPT9
vlan 50
name VLAN_NetMGT
vlan 51
name VLAN_CAS_MGT
vlan 52
name VLAN_CAM_MGT
vlan 210
name VLAN_DEPT1_Auth
vlan 211
name VLAN_DEPT2_Auth
vlan 220
name VLAN_DEPT3_Auth
vlan 226
name VLAN_DEPT4_Auth
vlan 227
name VLAN_DEPT5_Auth
vlan 228
name VLAN_DEPT6_Auth
vlan 229
name VLAN_DEPT7_Auth
vlan 230
name VLAN_DEPT8_Auth
vlan 232
name VLAN_DEPT9_Auth
Interface Configs
interface GigabitEthernet3/41
description "Link to Cisco CAM-PRI eth0"
switchport access vlan 52
switchport mode access
spanning-tree portfast
spanning-tree guard root
no cdp enable
no ip address
interface GigabitEthernet3/42
description "Link to Cisco CAM-FO eth0"
no cdp enable
no ip address
interface GigabitEthernet3/43
description "Trunk to Cisco CAS-PRI eth1 / UN-Trusted Network"
switchport
switchport trunk native vlan 777
switchport mode trunk
switchport trunk allowed vlan 210,211,220,226-230,232
interface GigabitEthernet3/44
description "Trunk to Cisco CAS-FO eth1 / UN-Trusted Network"
switchport
interface GigabitEthernet3/46
description "Trunk to Cisco CAS-PRI eth0 / Trusted Network"
switchport
switchport trunk native vlan 700
switchport trunk allowed vlan 10,11,20,26-30,32,50-51
interface GigabitEthernet3/48
description "Trunk to Cisco CAS-FO eth0 / Trusted Network"
switchport
interface GigabitEthernet1/1
description "Trunk link to DEPT1 Access SW"
switchport
!------- Example of VLAN Interface --------
interface Vlan10
description "DEPT1 VLAN"
ip address x.x.10.1 255.255.255.0
ip helper-address x.x.50.5
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
no ip mroute-cache
!------- No VLAN Interface for AUTH VLAN 210 --------
Access Switch Configuration
interface GigabitEthernet0/1
description "Trunk Link to Core Switch"
switchport
no ip address
interface GigabitEthernet0/6
switchport access vlan 30
no cdp enable
no ip address
Is the above config correct?
gghayur
The config looks ok but we recommend using bogus native vlans to be used on the trusted and untrusted trunk ports.
When you put the client machine on gig 0/6, make sure it is moving the vlan from 30 -->230.
Syed
Not applicable
Refer the NAC configuration guide for more information. Go to device management and look for the configuration.
gghayur
Syed
By bogus I assume you mean something like;
interface Vlan700
description "BIT BUCKET for unused ports"
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
no ip mroute-cache
shutdown
