Cisco 2611 XM
Jul 24th, 2007
I use Cisco 2611 XM for my existing setup of IPLC-VOIP technology with a 4 voice extensions, I plan to increase the number extensions to 8, Is my existing model is compatible for this increase ?
Amit Singh Tue, 07/24/2007 - 04:20
What do you mean by 4 voice extensions, is that the FXS port count or the PRI lines count.
2611XM has 2 WIC slots which can take upto 4 Pri lines depending on the WIC card used. You can increase it max to 6 lines by using an avaialble NM slot. You can add a wide variety of Voice WICS to it. Please the modules supported in the NM slots.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet0900aecd800fa5be.html
HTH,
-amit singh
gsramaswamy Tue, 07/24/2007 - 05:13
I try to mean 4 analog phone lines connected to the router used for VOIP thru IPLC technology.
Can this be increased to 8 analog phone lines with the same router model ?
