07-24-2007 04:48 AM - edited 03-11-2019 03:48 AM
Hi there,
I know this is a basic question, but bear with me since I am fairly new to this forum.
I would like to know if there is any way that I can retrieve the statistics (CPU usage, Traffic, etc,etc) from ASA and PIX so I can have some history of it. I know I can take a snapshot of it, but is it possible to keep a record of this information?
Also, I know that in terms of traffic I can use an application like Cacti to monitor (and produce graphs) for the interfaces but I don't know if it is possible to record everything in it (for example, memory and cpu utilization).
Thanks in advance,
Paulo
Solved! Go to Solution.
07-24-2007 05:15 AM
Yes you can.
Cacti, MRTG, NMIS, JFFNMS
Can all be used to keep historical stats of these values.
07-24-2007 05:15 AM
Yes you can.
07-24-2007 07:55 AM
Thank you. I'll try it with Cacti.
