Voice gateway
Jul 24th, 2007
Team --
I have two issues that may be related.
We have multiple sites connected on a frame network, these sites have Avaya PBXs with Cisco gateways. The Gateways have E&M cards for the 4-digit dial.
Problem 1) When our Delaware office (4-digit) dials another office they just get dial tone.
Problem 2) When any other office calls the Delaware office, they can establish the call but the volume is very very low.
We upped the input gain all the way with no luck. All other offices are working fine, and the PBX manufacture says that it is not them.
Does anyone have any suggestions for where can can begin looking?
Thank you.
Overall Rating: 3 (2 ratings)
paolo bevilacqua Wed, 07/25/2007 - 05:25
  • Hall of Fame,
    Founding Member
1. Likely lack of "direct-inward-dial" on the incoming DP, or lack of said DP.
2. Likely wiring issue on the E&M, as you know there are various types of E&M, you would need to make sure you have it setting for the PBX.
Hope this helps, please rate post post if it does!
ouhakheme Wed, 07/25/2007 - 10:39
Seems to be a bad port, port 2 is working fine.
Thanks!
paolo bevilacqua Wed, 07/25/2007 - 17:54
  • Hall of Fame,
    Founding Member
Swap ports to confirm. One port working doesn't implies that cabling/pbx if fine on the other too.
ouhakheme Wed, 07/25/2007 - 17:57
Fair enough, we will be testing tomorrow morning with the new card. I will let you know how it goes.
