Code for calls
Jul 24th, 2007
Hello!
Is there a way to authorize calls without forced authorization codes?
I want to configure a phone to use a authorization code before making any calls(no matter where the call is being made - national, mobile, international).
gogasca Tue, 07/24/2007 - 07:48
  • Green, 3000 points or more
I can think in extension Mobility.
You setup all phones to not allow anything but internal|911 calls, unless you login with your userid and pin and your EM profile becomes active.
I have seen that some Telcos provides something similar to FAC.
paolo bevilacqua Tue, 07/24/2007 - 08:44
  • Hall of Fame,
    Founding Member
Yes you can do manipulating your route patterns. choose a special prefix and when it is present, the call goes through.
