WAN Router Help
Jul 24th, 2007
I was given a task to change over a site from one provider to another. I do not have site access as of yet so I am gathering information remotely.
a sh run shows no T1 controllers and only a serial interface with an IP. Then a Fa0 with an IP.
Now the serial interface as no channel groups or timing line encoding on it.
The router is a 1721
SO I am assuming there is an external CSU/DSU on location.
The new provider will not have one and its only a smart jack.
According to the sh ver listed below. There is a WIC-T1-dsu
now my question is, I am not 100% sure it has a built in CSU/DSU.
I pasted below a sh ver and Sh diag. Can someone give me some information on will this router work. Like can I just run RJ45 from the smart jack and connect it to the router?
IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEAS
E SOFTWARE (fc1)
Synched to technology version 12.2(5.4)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 11-Apr-02 21:54 by ealyon
Image text-base: 0x80008124, data-base: 0x807976DC
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-Y-M), Version 12.2(4)YA2, EARLY DEPLOYMENT RELEASE SO
FTWARE (fc1)
York_1721 uptime is 31 weeks, 5 days, 19 hours, 50 minutes
System image file is "flash:c1700-y-mz.122-4.YA2.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 29492K/3276K bytes of memor
y.
Processor board ID FOC062002RR (2465657608), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
WIC T1-DSU
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
#sh diag
Slot 0:
C1721 1FE Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
PCB Serial Number : FOC062002RR
Part Number : 73-7546-01
Board Revision : A0
Fab Version : 04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 5A 41 01 00 C1 8B 46 4F 43 30 36 32
0x10: 30 30 32 52 52 82 49 1D 7A 01 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
FT1
Hardware revision 1.3 Board revision C0
Serial number 0027926602 Part number 800-03279-04
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 2
0x20: 02 11 01 03 01 AA 20 4A 50 0C CF 04 00 00 00 00
0x30: 60 00 00 00 02 03 19 01 FF FF FF FF FF FF FF FF
sundar.palaniappan Tue, 07/24/2007 - 07:26
  • Green, 3000 points or more
It appears you have an integrated T1 WIC CSU/DSU. You should be able to connect the T1 cable directly to the SJ. If you want to change any of the CSU/DSU default configuration you need to use the 'service-module' command under the Serial interface.
Sundar
bryan.farmer Tue, 07/24/2007 - 12:32
Agree with last post, you have an integrated T1 WIC.
You'll see it if you issue a show interface
The service-module commands will only show in the config if you change defaults (ie - b8zs/esf/timeslots 1-24).
And yes, it uses an RJ45 connection.
