VPN Troubleshooting
Answered Question
Jul 24th, 2007
Argghh - I'm pulling my hair out.
I'm having problems with this VPN stuff. I have read piles of books etc and I just can't see what the problem is.
I have a PIX515E which has a outside interface with a private IP address which connects to the inside of a 3660 Router. The router nat the PIX ip to a internet routable IP. No access-list are on the router and traffic flows thorugh to other internal IPs fine.
The VPN Cisco Client is saying:
Cisco Systems VPN Client Version 5.0.00.0340
Copyright (C) 1998-2006 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
259 16:36:02.050 07/24/07 Sev=Info/4 CM/0x63100024
Attempt connection with server "*.*.*.*"
260 16:36:02.060 07/24/07 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with *.*.*.*.
261 16:36:02.090 07/24/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Unity)) to *.*.*.*
262 16:36:02.100 07/24/07 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
263 16:36:02.100 07/24/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
264 16:36:07.568 07/24/07 Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
265 16:36:07.568 07/24/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to *.*.*.*
270 16:36:22.589 07/24/07 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=B9A3A69D5B3192A7 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
271 16:36:23.090 07/24/07 Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=B9A3A69D5B3192A7 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
272 16:36:23.090 07/24/07 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "*.*.*.*" because of "DEL_REASON_PEER_NOT_RESPONDING"
etc
The PIX 515 has increase in the In Octets and also packets but has the same amount of dropped packets in a Show ISAKMP command:
Global IKE Statistics
Active Tunnels: 0
Previous Tunnels: 0
In Octets: 46152
In Packets: 56
In Drop Packets: 56
In Notifys: 0
The ISAKMP is as follows:
crypto ipsec transform-set Myset esp-3des esp-sha-hmac
crypto dynamic-map TestMap 1 match address CorpOffice
crypto dynamic-map TestMap 1 set transform-set Myset
crypto map Test 10 ipsec-isakmp dynamic TestMap
crypto map Test interface outside
crypto isakmp identity hostname
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp nat-traversal 20
crypto isakmp am-disable
crypto isakmp disconnect-notify
crypto isakmp reload-wait
Any pointers on how to debug or even fix - much much much appreciated!!!!
Ed
Correct Answer by 1cmerchant about 9 years 12 months ago
Ed,
Does the rest of your network know a route back to the network you are using for the VPN? Assuming that you have an 'Inside' interface connected to your network, other networking devices in your network would need to know that IP address in order to send traffic back to the network subnet you are assigning to the VPN clients.
Carl
Overall Rating: 5 (1 ratings)
mattiaseriksson Tue, 07/24/2007 - 14:56
  • Bronze, 100 points or more
Ed,
It looks like you use IP address to connect, so you shold use "crypto isakmp identity address" instead of "crypto isakmp identity hostname".
And you don't really need the match statement in the dynamic crypto map so you can try to remove it.
If this does not help it would be useful to see the debugging from the PIX.
Fernando_Meza Tue, 07/24/2007 - 23:10
  • Gold, 750 points or more
HI .. here is a working config you could use as reference ..
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication LOCAL
crypto map outside_map interface outside
isakmp nat-traversal 30
isakmp policy 100 authentication pre-share
isakmp policy 100 encryption des
isakmp policy 100 hash md5
isakmp policy 100 group 2
isakmp policy 100 lifetime 86400
vpngroup VPNGROUP address-pool VPNGROUP-Pool
vpngroup VPNGROUP dns-server x.x.x.x
vpngroup VPNGROUP default-domain domain.net
vpngroup VPNGROUP idle-time 1800
vpngroup VPNGROUP password ********
username remoteuser password remoteuser privilege 2
I hope it helps .. please rate it if it does !!!
edw Wed, 07/25/2007 - 02:38
I got a bit futher after posting my message. The problem was the crypto isakmp match address command!
So after a few bumps I can connect no errors that I can see etc. However now I pass any traffic - debug only referances this
Built ICMP connection for faddr 10.10.10.18/1024 gaddr 10.9.9.10/0 laddr 10.9.9.10/0
Teardown ICMP connection for faddr 10.10.10.18/1024 gaddr 10.9.9.10/0 laddr 10.9.9.10/0
Any ideas why I seem to be sending but not getting a response back ??
Ed
edw Wed, 07/25/2007 - 08:13
I honestly can't see why this isnt working ?
encryption des
hash md5
group 2
lifetime 86400
I have nat 0 (inside) access-list Test
access-list Test extended permit ip any 10.10.10.0 255.255.255.0
Is there other command I should be seeing ?? I have entered sysopt connection permit-vpn (thou it doesnt show up in config.
Thanks for any desperate help
Ed
edw Wed, 07/25/2007 - 09:04
Okay
5 POINTS FOR THE FIRST CORRECT ANSWER!
I can connect and auth with no erros but not pass traffic. I get this in the debug when I try to ping.
The config without correct IP's is:
PIX Version 7.2(2)
hostname VPN-Headache
interface Ethernet0
nameif outside
security-level 0
ip address 10.11.1.1 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0
dns server-group DefaultDNS
domain-name default.domain.invalid
access-list Out extended permit tcp host 10.10.1.201 any eq ftp
access-list In extended permit udp host 10.11.1.2 host 10.250.250.201 eq tftp
access-list VPNTest extended permit ip any 192.168.20.0 255.255.255.0
pager lines 24
ip local pool Off-Pool 192.168.1.50-192.168.20.1.60
nat-control
global (outside) 2 10.250.250.10
nat (inside) 0 access-list VPNTest
nat (inside) 2 10.10.1.0 255.255.255.0
static (inside,outside) 10.250.250.201 10.10.1.201 netmask 255.255.255.255
access-group In in interface outside
access-group Out in interface inside
route outside 0.0.0.0 0.0.0.0 10.11.1.2 1
route inside 10.10.1.0 255.255.255.0 10.10.10.2 1
group-policy DfltGrpPolicy attributes
banner value Testing Default
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec l2tp-ipsec
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
split-tunnel-network-list none
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools none
client-firewall none
client-access-rule none
group-policy Test internal
group-policy Test attributes
banner value Test Test
wins-server value 10.10.1.2 10.10.1.5
vpn-session-timeout 30
ipsec-udp enable
crypto ipsec transform-set Myset esp-des esp-md5-hmac
crypto dynamic-map Test1 1 set transform-set Myset
crypto map VPN 10 ipsec-isakmp dynamic Test1
crypto map VPN interface outside
encryption des
hash sha
group 2
lifetime 86400
tunnel-group Off type ipsec-ra
tunnel-group Off general-attributes
address-pool Off-Pool
authentication-server-group (outside) Mygroup
accounting-server-group Mygroup
default-group-policy Test
tunnel-group Off ipsec-attributes
pre-shared-key *
Ed
Correct Answer
1cmerchant Wed, 07/25/2007 - 09:17
Ed,
Carl
edw Wed, 07/25/2007 - 09:25
Yes I have a route on my internal router pointing 192.168.1.0 255.255.255.0 10.10.10.1
The gateway my clients get given is 192.0.0.1 255.0.0.0
Not sure why ??
Ed
edw Wed, 07/25/2007 - 09:56
I checked this last night - and thought it was correct but after your post, I checked again. Guess what - it was pointing to the old firewall. lol
Can't believe it! Thanks for the heads up - 5 points as promised!
Ed
