How to force master in VIP and int redundancy
Answered Question
Jul 24th, 2007
Do the commands "redundancy force-master" and "ip redundancy master" work when using VIP and virtual interface redundancy? The documentation seems to speak of those commands in a box-to-box redundancy context. I know there are caveats to using them together. My preference is to use redundancy force-master if it will work, since that is not saved in the config.
Correct Answer by Syed Iftekhar Ahmed about 9 years 7 months ago
There is no such command for VIP Redundancy
You can use one of the following options to achieve this
* physically removing one of the upstream or downstream cables
*changing the preempt command in the configuration, first remove it form the master, then add it to the backup and it will take master ship of the virtual routers
* making the critical service to fail (do not suspend, that won?t trigger the failover)
Hope it helps
Syed Iftekhar ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Tue, 07/24/2007 - 09:51
Hope it helps
Syed Iftekhar ahmed
eleibowitz Tue, 07/24/2007 - 11:35
Thanks, Syed. I have used the preempt option before, but I was hoping there was a simpler way.
