Rob Huffman Tue, 07/24/2007 - 08:39
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Justin,
As you have seen, the "Disable PC Port" setting is not available on 7912's. The only way to disable the PC is via your Switchport Config (setup with only Voice VLAN and no Data VLAN).
Hope this helps! I know it's a pain :(
Rob
PS: Hope all is well in Banff!
Justin Brenton Tue, 07/24/2007 - 08:56
  • Silver, 250 points or more
Hey,
Thanks for the help, I figured that would be my only option.
All is well in Banff. How are thing's in Calgary?
Thanks Rob
Rob Huffman Tue, 07/24/2007 - 12:05
  • Hall of Fame,
    Founding Member
Hi Justin,
All is well in the Cowtown! Busy but good :)
Take care,
Rob
