Ring No Answer - Force Forwarding
Jul 24th, 2007
Hello - is there some way to configure a phone, or the system, so that a Missed Call causes a phone to thereafter Forward All Calls to Voicemail? Thanks.
Overall Rating: 3 (1 ratings)
Rob Huffman Tue, 07/24/2007 - 09:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ellen,
There is no "Built-In" Phone or System setting that will accomplish this :( I am guessing that this is more of a Training issue. The best that you can do is to configure the "Foward No Answer" setting to go to Voicemail, which you have probably already done.
Hope this helps!
Rob
