Running the perl logrot.pl -v
Jul 24th, 2007
I pretty much understand the concept of running the perl logrot.pl -v and -c to minimize the syslog.log files. It is any way I can get to run in a batch file or script to run on a certain schedule or does this has to be done manually? Just curious I'm still learning the product.
Joe Clarke Tue, 07/24/2007 - 09:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can schedule it using cron on UNIX or at on Windows.
Once you've verified things work on-demand, you can setup cron on UNIX:
0 1 * * * /opt/CSCOpx/bin/logrot.pl 2>&1 | /usr/lib/sendmail root
or AT on Windows:
at 01:00 /every:M,T,W,Th,F,S,Su C:\progra~1\CSCOpx\bin\perl.exe C:\progra~1\CSCOpx\bin\logrot.pl
(This assumes CiscoWorks is installed in the default location on Windows.)
Those commands will run logrot every day at 1:00 AM. The UNIX cron line will
also send all output of the command to root via email.
dionjiles Tue, 07/24/2007 - 10:52
Thanks, once again I knew I would find the answer here.
