Aggressive Mode Configuration
Jul 24th, 2007
In a VPN configuration I have a cisco 1700 router and on the other side I have a Firewall. I need to configure the Aggressive Mode that the firewall has already set on the router, so both devices can manage dinamic IP adresses from the ISP.
Anonymous (not verified) Mon, 07/30/2007 - 09:23
To configure the Cisco VPN 500x to support LAN-to-LAN connections, it is necessary to define the tunnel configuration, as well as the IP communication parameters that are used in the tunnel. This is accomplished in two sections, the [Tunnel Partner VPN x] section, and the [IP VPN x] section. For any given site-to-site configuration, the (x) defined in these two sections must match, so that the tunnel configurations are properly associated with the protocol configuration.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2301/products_tech_note09186a00801e4db9.shtml
