ISAKMP Auth failing
Jul 24th, 2007
I'm having issues getting the preshared key configured on both ends of a tunnel. I can change the key on the host FW but am unable to change the key on the remote FW. It just errors when issuing a command telling me that there's already a key assigned for the IP address requested. How can I change the key on the remote firewall?
sathishd-aus Wed, 07/25/2007 - 01:14
You are configuring preshared key on PIX/ASA or in router.
Sponge1771 Wed, 07/25/2007 - 06:17
Lan to Lan PIX VPN tunnel. I can change the preshared key on the host PIX, but the remote PIX will not allow me to change the key setting in the config t mode.
Jon Marshall Wed, 07/25/2007 - 10:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Try deleting the existing one first ie.
no isakmp key ******** address "IP address"
and then add your new one.
Jon
Sponge1771 Wed, 07/25/2007 - 12:55
I don't know the key, but did not try entering *******, will just using asterisks work?
Jon Marshall Mon, 08/06/2007 - 13:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Have you tried this command. Yes using just asterisks should remove the key.
Jon
krishnakomiti Tue, 07/31/2007 - 02:56
Use the below command to delete:
"no isakmp key *********** address xxx.xxx.xxx.xxx netmask 255.255.255.255"
Here ***** means your preshared key and XXX.XXX. means your destination IP address you have to use to delete and try add new one.
Ragards,
Krishna.
Sponge1771 Tue, 07/31/2007 - 05:55
The problem is, I took over for some people that left and didn't document well, so I do not know what the preshared key is. Is there a way to either retrieve it or remove that command without setting the device back to defaults and starting from scratch?
grahambartlett Mon, 08/06/2007 - 04:38
Hi Sponge1771
You have a few methods to see the keys... ;-)
1. Copy the running-config to a tftp server (copy runn tftp)
2. Show the running config so you can see the pre-shared keys.
more system:running-config
3. Enable a https server and view this using it.
The choice is yours...
If you find this post helpful please mark it :-)
ciscosom Mon, 08/06/2007 - 12:42
If you are looking for the Pre-shared key issue "sh crypto isakmp key" on the router to see the Key that was set on the ISAKMP .
Sponge1771 Mon, 08/06/2007 - 12:47
That shows the isakmp configuration, but the key is blanked out with *******.
