ASA NAT one external IP to two internal machines
Jul 24th, 2007
Can it be done? I tried to split the IP into ports using static (dmz,outside)tcp external www internal www
ACL works as I tried it with a 1:1 translation, but doesnt with I try it this way. Is there an alternative? The company is short a public IP and needs to have it working this way.
sundar.palaniappan Tue, 07/24/2007 - 14:26
  • Green, 3000 points or more
You can configure port redirection to forward traffic based on global IP & port to the appropriate interval server. Here's a small example.
static (dmz,outside) tcp 209.165.201.5 smtp 10.1.1.6 smtp netmask 255.255.255.255
static (dmz,outside) tcp 209.165.201.5 www 10.1.1.3 www netmask 255.255.255.255
Sundar
tahequivoice Wed, 07/25/2007 - 05:06
HI, When I posted this, the static translations weren't working. After I posted I blew them away and re-entered them one at a time and tested them and they started working. I had them done correctly, but for some odd reason they just refused to work, but work now that I redid them.
rochopra Tue, 07/24/2007 - 14:29
  • Cisco Employee,
This should work fine, make sure you also include ports in ACL like following example:
access-list 101 permit tcp any host external eq www
access-group 101 in interface outside
Also ports for 2 ip addresses should be different.
Hope this helps.
Rohit
chetankamra Tue, 07/24/2007 - 21:24
Try below command it works
1. Connects outside X.X.X.X on service 8080 to Internal Y.Y.Y.Y on service WWW.
-->(config)# static (inside,outside) tcp X.X.X.X 8080 Y.Y.Y.Y www netmask
255.255.255.255
2. Redirect Telnet requests for X.X.X.X to Y.Y.Y.Y by entering the following command:
--> config)# static (inside,outside) tcp X.X.X.X telnet Y.Y.Y.Y telnet netmask
255.255.255.255
Hope this will help
