ACS1113 & two factor authentication
mulhollandm
folks
another query!
i need to authenticate users by crytocard on the acs appliance but when i select the method of authentication i only have acs internal database an an other - no crypto
do i need another licence or is there an option somewhere to make this available
thanks to anyone taking the time to reply
rochopra
You need to configure cryptocard as Radius Token server in external user database.
Following link can give you information on how to configure token server in ACS:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs41/user/usrdb.htm#wp356090
Would like you to see following link though which refers that crypto card is not tested with latest version of ACS:
http://www.cisco.com/en/US/partner/products/sw/secursw/ps2086/products_device_support_table09186a00807144e4.html#wp27457
Hope this helps.
Rohit
rochopra
Hope this helps.
Rohit
