Agent Desktop auto login
Jul 24th, 2007
Hi all
Any one know how to:
- Agent Desktop auto login (user don't need to type user/pass)
- Agent Desktop auto login after failure or network problem (by default, when have problem, all agent is logout)
- Agent will have state ready after login
Thanks for help
Will vote 5* for you
Rob Huffman Wed, 07/25/2007 - 05:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi HD,
Have you looked into this setup?
Configure a "One Button Login" for IP Phone Agents
This document explains the procedure that allows IP Phone Agents to login without a prompt for a username, password, and extension in a Cisco Unified Contact Center (UCC) Express or Enterprise environment.
From this good Tech Note;
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a008029e6d5.shtml
Hope this helps!
Rob
conkinkinconkinkin Wed, 07/25/2007 - 19:03
Thanks, Rob
But i use agent desktop
Do you know how to set autologin with agent desktop?
conkinkinconkinkin Sun, 07/29/2007 - 18:27
Any one can help?
I think it is a need of all contac center
Any one know solution?
Thanks first
conkinkinconkinkin Sun, 08/05/2007 - 18:30
What do you think when talk about security?
Do you know that each person in contact center have one computer?
You think auto login, auto reconnect is unsecure??
I think auto login and auto reconnect is important function of contact center
Any one have solution?
