need QOS/policing help on a 6500 Sup7203BXL
Jul 24th, 2007
We have just installed a cisco 6500 and are trying to get our policing working for customers. The DSCP values seem to be getting lost. I have turned on "mls trust dscp" on the links to the core. We are also running MPLS on the core. Would this have an affect?
Here is some config from the switch.
class-map match-any MATCH-INTERNATIONAL
description Match any International Traffic
match ip dscp 5
match ip precedence 5
policy-map CUSTOMER_BWPLAN58_UPLOAD
class MATCH-NATIONAL
police cir 2097000 bc 393240 be 393240 conform-action transmit exceed-action drop violate-action drop
class MATCH-INTERNATIONAL
police cir 262000 bc 49155 be 49155 conform-action transmit exceed-action drop violate-action drop
interface Vlan3202
description Customer: via Vector Max-3202
ip address 123.100.119.62 255.255.255.240
no ip redirects
no ip proxy-arp
bgp-policy source ip-prec-map
service-policy input CUSTOMER_BWPLAN782_UPLOAD
service-policy output CUSTOMER_BWPLAN782_DOWNLOAD
We are also trying to use BGP table maps to set the dscp on outgoing traffic so we can rate limit international. These don't seem to work either.
Any help would be great. Thanks
Pavel Bykov Wed, 07/25/2007 - 12:39
MPLS uses EXP bits for QoS, but after stripping MPLS label, DSCP values are used. Are all labels stripped from packets going through Vlan 3202?
Also, IP precedence 5 = DSCP 40 (CS5)
and DSCP 5 is actually a non-RFC DSCP value, that sets unused and medium discard bits for Class Default (Best Effort)
Have you tried sniffing traffic, by using span-ports? Maybe packets already don't have precedence, or you are matching the wrong one...
