Nortel Contivity Client do not connect PIX 515E
Jul 24th, 2007
Hi Frds,
I have peculiar problem, my users are not able to connect to VPN using the Nortel Contivity client.
Acces Switch - Core - Firewall(pix) - Internet
This is my current setup. I am able to connect to Cisco client based vpn by NATting or PAT, but on the same setup, I am not able to use the Nortel VPN client.
mattiaseriksson Wed, 07/25/2007 - 04:56
  • Bronze, 100 points or more
NAT Traversal is not enabled by default in Nortel VPN Gateways. Verify if it is enabled in this case.
If it is enabled, check what UDP port that it's using, in case you have an outbound access-list.
Check your PIX logfile for other clues.
Hope that helps.
