cisco vpn client/PIX connectivity woes
Jul 24th, 2007
i'm pretty new to the pix world. i'm trying to learn a few things using various tutorials i've found on the net.
i have a pix 501 that i'm trying to use as a VPN endpoint. i have a winxp machine running vpn client 4.0.
here's the setup:
(internet)-----[cisco 831]-----[pix 501]-----(internal network)
i can connect to the pix and am assigned an IP address, but beyond this nothing happens.
i cannot look inside the internal network, and i cannot pass through the VPN to connect to the outside world either (browsing, etc).
here's my pix configuration. maybe someone can find something in here that will help.
i read someplace about something to do with a "split scope." while i wasn't really able to understand fully what that means, i gathered it had something to do with the pix dealing with two separate networks. is there some specific command that i need to implement? also, can someone give me the layperson's explanation of what this "split scope" does if it is the source of the problem?
i've attached a txt file with my pix config for review.
mattiaseriksson Wed, 07/25/2007 - 00:36
Is your vpn-client behind a NAT gateway? Then you need to enable NAT traversal.
isakmp nat-traversal 20
And the reason for split-tunneling not working could also be because the access-list statements have the wrong netmask.
Try changing:
access-list 101 permit ip
to access-list 101 permit ip
And the same with access-list 102.
You also don't need to permit vpn traffic, so you can remove the conduits:
conduit permit ip host any
And if you need to open for inbound traffic on your firewall you should use access-lists instead of conduits.
I hope this helps, pleas rate if it does.
