Invisible WLC?
PaulBullough
If I plug a 4400 WLC into a 3750 switch and look at the topology on Network Assistant connected to the switch I should actually see the WLC, shouldn't I?
It doesn't appear.
I believe I've configured the management interface and ports correctly on the WLC, as per the document: "Wireless LAN Controller and Lightweight Access Point Basic Configuration Example". The two are connected through a Gigabit port using copper.
Anything obvious I should check which might render the WLC completely invisible?
Paul.
htarra
Level 4
Level 4
I think it is possible to create a mobility group between a Catalyst 3750 Switch with an integrated controller and a 4400 Controller. For more information please click following URL:
http://www.cisco.com/en/US/products/ps6305/products_configuration_guide_chapter09186a008063ede0.html#wp1090318
