AAA and SNMP through VPN tunnel
Jul 25th, 2007
How can I send aaa traffic from my PIX506E to our ACSServer and SNMP traps to our monitoring station through a VPN tunnel?
Do I have to add the server with interface outside (like: aaa-server CiscoACS (outside) host ACSSErver)
and add the outside interface to the access-list for the VPN traffic.
Can't I use the inside interface because our outside interface has a public IP address and that will be difficult to settup on the ACS Server?
Jagdeep Gambhir Fri, 07/27/2007 - 11:07
  • Red, 2250 points or more
If you are using it for authentication on pix then we need this command,
username Test password cisco
username Test privilege 15
aaa-server TACACS protocol tacacs+
aaa-server TACACS (outside) host 10.130.102.191 cisco timeout 10
Configuring Extended Authentication (Xauth)
http://www.cisco.com/en/US/docs/security/pix/pix63/configuration/guide/basclnt.html#wp1066294
Hope that helps !
