TKIP_REPLAY error
I am getting the following errors when devices try to authenticate, we are using WPA-PSK TKIP and the keys definitley do match, funnily though, the devices are able to ping the gateway:
*Mar 1 03:21:49.628: DOT11 EVENT:(adding)client->key_details.encrypt_type is 20
*Mar 1 03:21:49.628: dot11_aaa_auth_request: Received dot11_aaa_auth_request for client 0002.7266.c731
*Mar 1 03:21:49.628: dot11_aaa_auth_request: SSID: XXXXX_XXXXX, Mac Address: 0002.7266.c731, auth_algorithm 0
*Mar 1 03:21:49.628: dot11_aaa_add_dot11_client_entry: AAA Client entry (0002.7266.c731, F8A74C) is added to the client list
*Mar 1 03:21:49.708: DOT11 EVENT:Freeing packets with previous MIC
*Mar 1 03:21:49.715: dot11_aaa_send_response: wlccp_ap_auth_method_done 50, method_done 8
*Mar 1 03:21:49.715: dot11_aaa_send_response: Sending response: 2 for: 0002.7266.c731
*Mar 1 03:21:49.715: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0002.7266.c731 Associated KEY_MGMT[WPA PSK]
*Mar 1 03:21:49.715: dot11_aaa_client_associate: Associated 0002.7266.c731
*Mar 1 03:21:57.921: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x7) received from 0002.7266.c731.
*Mar 1 03:21:58.202: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x8) received from 0002.7266.c731.
*Mar 1 03:21:58.206: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x8) received from 0002.7266.c731.
*Mar 1 03:21:58.921: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x9) received from 0002.7266.c731.
*Mar 1 03:21:58.952: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x9) received from 0002.7266.c731.
*Mar 1 03:21:58.960: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x9) received from 0002.7266.c731.
*Mar 1 03:22:04.201: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0xB) received from 0002.7266.c731.
*Mar 1 03:22:04.779: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0xD) received from 0002.7266.c731.
*Mar 1 03:22:06.862: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0xF) received from 0002.7266.c731.
*Mar 1 03:22:07.640: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x10) received from 0002.7266.c731.
*Mar 1 03:22:08.357: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x11) received from 0002.7266.c731.
*Mar 1 03:22:11.354: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x15) received from 0002.7266.c731.
*Mar 1 03:22:13.611: %DOT11-4-TKIP_REPLAY: TKIP TSC replay was detected on a packet (TSC 0x19) received from 0002.7266.c731.
*Mar 1 03:22:49.740: %DOT11-4-MAXRETRIES: Packet to client 0002.7266.c731 reached max retries, removing the client
*Mar 1 03:22:49.740: Client 0002.7266.c731 failed: reached maximum retries
*Mar 1 03:22:49.740: dot11_aaa_client_disassociate: Received disassociation notice for 0002.7266.c731
*Mar 1 03:22:49.740: dot11_aaa_delete_client_entry: AAA Client (0002.7266.c731, F8A74C) is deleted
*Mar 1 03:22:49.740: dot11_auth_client_abort: Received abort request for client 0002.7266.c731
*Mar 1 03:22:49.741: dot11_auth_client_abort: No client entry to abort: 0002.7266.c731 for application 0x1
*Mar 1 03:22:49.741: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0002.7266.c731 Reason: Previous authentication no longer valid
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
