Clientless VPN SSH problem
Jul 25th, 2007
I'm having trouble using the SSH plugin from the ASA clientless VPN.
All works fine, the RDP plugin FTP and so on are ok and work fine, but when I try to connect to a server with SSH all I get is a black window in which I cannot type anything.
I am using an ASA 5510 with software v. 8.0(2), ASDM version 6.0(2).
I'm using the latest Java plugin.
Thank you.
Gabi.
gabriel.gearip Wed, 07/25/2007 - 04:33
Actually after inserting the username and password it gives the message Not connected - offline.
Gabi.
med_ddevlin Thu, 07/26/2007 - 11:45
Which version ssh are you running? The Java SSH only supports version 1.
Please rate if this helps.
