DFM 2.0.9 customizable interface group problem.
Hi all.
we are using LMS 2.6 and I am trying to create a user defined group (in DFM) for a number of interfaces to change thresholds for only those interfaces.
The problem is i can't populate the customizable access,interface or trunk groups in any possible way it seems. I have tried adding same/simmilar rules as the system groups such as Interfaces.Type contains "ETHER" with no luck. (Also cust interface group 1 and 2 are missing in "group administration???)
In the customizable group for devices it is OK.
after the group is modified I can select it in "managing thresholds" but clicking on "view interfaces" shows no interfaces. just the pop up "The selected group has no devices.
Please select a group with devices" (the system interface groups are showing device/interfaces).
Is it me, a bug or a feature ?
Hi agian
It was me..
I found in the documentation this info.
If the interface or port appears as a member, that group is the overriding group. (Ports and interfaces are only listed as members in the overriding group.)
So I had to change priority and APPLY before anything shows up in that group. A bit different than for Devices.
now I only have to find interface group 1 and 2 ??
