Stickyness across multiple VIPs
Jul 25th, 2007
I was wondering if anyone knows if it is possible to implement stickyness across multiple VIPs. In other words, if a client hits a specific VIP on a specific TCP port, then hits a different VIP on a different tcp port, can stickyness be configured to stick that client to the same server?
Thanks!
Martin Kyrc Wed, 07/25/2007 - 06:18
u talk about stickineess on the CSM? it's possible :), but be careful...
example:
vserver1: vip1:port1
rserver1: rserver_ip1:portX
vserver2: vip2:port2
rserver2: rserver_ip1:portY
and one sticky group for both server farms (one for rserver1, second for rserver2).
first session is established to vserver1:
- sticky is recorded to rserver1 (rserver_ip1:portX)
second session is established to vserver2:
- sticky exists (client matched the sticky rule)
- session is not load-balanced, but connected to rserver by sticky record (!), in other words, session is directed to rserver_ip1:portX and no to :portY
^^^ answer to your question: it's possible :), but be careful... in other words, it's possible if the service on the server side is running on the same real server and port (portX=portY). other, use different sticky group for second server farm.
is it answer to your question?
regards,
martin
dbrisson Wed, 07/25/2007 - 06:33
I apologize...I neglected to mention that this is for a CSS 11503.
Martin Kyrc Wed, 07/25/2007 - 06:53
I think, it's not possible, because CSS use sticky definition for each content rule (unlike CSM, where you define sticky group and you can associate one group with some server farm. the similar situation is for ACE.).
martin
Syed Iftekhar Ahmed Wed, 07/25/2007 - 10:04
  • Blue, 1500 points or more
The workaround in your case would be to use a single content rule, with only a
virtual address specified (Do not specify a port). As a result the rule will
listen on all ports, and since it's a single rule, the same sticky behavior will apply for any ports being connected to.
I have seen & done similar implementations where it was needed to stick http & Https clients to the same server.
Hope it helps
Syed Iftekhar Ahmed
