Unity Call Handler reports
Answered Question
Jul 25th, 2007
Unity Unified Messaging 4.0(4)SR1 with off-box Exchange - Call Manager 4.1.3sr3a
I am running a Call Handler report from Unity Sys Administration, but there is no data in the Key columns - they all return 0. I can see what appears to be correct data in totals, DTMF ID, and hang-ups, but the report doesn't show any data for the single-digit exits from the menu, and I know that the menu options do get used by callers. Anyone know how I can get this report to show this data?
Correct Answer by rob.huffman about 9 years 6 months ago
Hi David,
It sounds like you are hitting this bug;
CSCeg07962 Bug Details
Headline Conversation does not log call handler exit reason properly
First Found-in Version 4.0(4)
Symptom:
Call Handler exit methods are not logged accurately in the System Call Handler
Traffic Report.
Condition:
Cisco Unity 4.0(4) and earlier when running the System > Call Handler Traffic
report from the Cisco Unity Administrator.
Workaround:
For 4.0(4), ES56 is available to fix this problem.
This problem is fixed in 4.0(5) and later.
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
rob.huffman Wed, 07/25/2007 - 06:36
Hi David,
Symptom:
Traffic Report.
Condition:
Workaround:
Hope this helps!
Rob
mzsaad123 Wed, 07/25/2007 - 06:43
Rob,
How long data is kept before it is deleted?
How back can I go in Unity for Call Handler reports?
I tried going a month back and I saw all zeros in days which are more than 5/6 days back.
