Can't ping Pix over VPN but can PC's
Jul 25th, 2007
I can ping PC's over our remote VPN (concentrator to a remote Pix) but not the Pix that is over at the remote site. I am trying it's local IP address over the VPN.
However the PC's on the Pix's LAN can.
I can get on the ADSM using the Pix external IP, but I'd rather use the internal IP over the VPn tunnel.
Let me know what info you need.
mattiaseriksson Wed, 07/25/2007 - 06:35
  • Bronze, 100 points or more
Hi, you should use the "management-access inside " command.
whiteford Wed, 07/25/2007 - 06:47
Why is it I can't log into that with my forum username and password? Do I need a high level?
whiteford Wed, 07/25/2007 - 07:02
Sorry too about this, but I can't find this managment pane to enable this option on an interface via the ADSM.
mattiaseriksson Wed, 07/25/2007 - 07:15
Ok, and I really don't know about asdm.
Try to get on the console with ssh and enter the command, that must be a lot easier.
acomiskey Wed, 07/25/2007 - 07:15
  • Green, 3000 points or more
Try this...
Tools -> Command Line Interface -> Select Multiple line -> In the text box type...
config t
and select "Send"
whiteford Wed, 07/25/2007 - 07:20
I'll try that this won't change my current access over the Internet?
mattiaseriksson Wed, 07/25/2007 - 07:22
No. It will only enable management access over the vpn.
acomiskey Wed, 07/25/2007 - 07:24
No, it should only change access when connected to the ASA via the vpn.
whiteford Wed, 07/25/2007 - 07:25
The reason I can't ping it over the VPN but can on-site, could this be a rule issue?
whiteford Wed, 07/25/2007 - 07:30
This is the error I got:
Result of the command: "conf t"
The command has been sent to the device
Result of the command: "management-access inside"
ERROR: % Invalid input detected at '^' marker.
acomiskey Wed, 07/25/2007 - 07:35
Weird, this is what I get...
Result of the command: "config t"
mattiaseriksson Wed, 07/25/2007 - 07:29
It could be blocked. If you already have management-access inside enabled, rules could be the cause of the problem. Otherwise it is unlikely.
acomiskey Wed, 07/25/2007 - 07:36
Found it...
Config -> Device Administration -> Management Access -> Select inside
whiteford Wed, 07/25/2007 - 07:39
Right I have selected the inside interface, but still no joy on connecting to the local IP. A remote user in that same subnet as the Pix can though.
whiteford Wed, 07/25/2007 - 07:46
7.1(2)
Would the fact that I don't have a service policy rule be a problem too with this?
mattiaseriksson Wed, 07/25/2007 - 08:01
It should not be a problem, this is a global command.
Can you execute "show management-access" in config mode?
whiteford Fri, 07/27/2007 - 05:02
I can now ping it's internal address over the VPN, but can't accesses it via the ADSM, any ideas?
management-access shows local_network
acomiskey Fri, 07/27/2007 - 05:17
you need to add
http outside
whiteford Fri, 07/27/2007 - 05:38
Still no luck, I put this in:
http 192.168.9.9 255.255.255.255 VPN
VPN is our tunnel to my office
