ATA question
Jul 25th, 2007
Does the Cisco ATA support two independant lines? I know that it has two analog ports, but my impression from the Cisco product information page is that only the 188 will support two separate lines and not the 186.
-Shikamaru
alessandro.dona Thu, 07/26/2007 - 01:07
I think both support two separate lines.
In ata 186 line 1 is associated to the mac address of the ata (i.e aaaabbbbcccc)
Line 2 is asscociated to a fake mac address
01aaaabbbbcc.
shikamarunara Thu, 08/02/2007 - 12:07
No, actually I think that is incorrect. The second mac address will lost its two leading zeros and an 01 is added at the end.
-Shikamaru
j.huizinga Fri, 08/03/2007 - 01:02
  • Silver, 250 points or more
One thing to remember with ATA
Only one port supports G711 and G729
The other port only supports G711
You can configure this, but default port 1 supports both codecs and port 2 only G711
Very annoying when you what to terminate VOIP g729 calls to port 2
Jan
