3560 socket question
Jul 25th, 2007
I have a problem getting the address 68.212.76.6 socket number 10001, through to the 10.10.4.x address in this switch.
At the switch and station level I can ping the address, however I can only telnet to the port when logged into the switch, not from the 10.10.4.x station. I can also get to the address and socket from the 17.x.x.x network, withouth issue.
As you can see I have even added an access list which allows any to any inside the switch.
I would like to understand if you see anything that would stop the socket from reaching the 10.10.4.x station.
I cannot see anything however it is still not getting to the end station on the 10.10.4.x side.
Below is the config file:
Building configuration...
Current configuration : 2610 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname test
enable secret 5 $1
no aaa new-model
ip subnet-zero
ip routing
ip name-server x.x.x.x
ip dhcp excluded-address 10.10.4.1
ip dhcp pool test-1
import all
network 10.10.4.0 255.255.255.0
default-router 10.10.4.1
ip dhcp-server 10.10.4.1
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 2
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
no switchport
ip address 172.16.0.206 255.255.255.0
ip access-group 10 in
ip access-group 10 out
interface GigabitEthernet0/2
interface Vlan1
no ip address
interface Vlan2
ip address 10.10.4.1 255.255.255.0
ip default-gateway 172.16.0.1
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.1
ip http server
access-list 10 permit any
snmp-server community public RO
snmp-server community private RW
control-plane
line con 0
line vty 0 4
password xxxxxxx
no login
line vty 5 15
password xxxxxxx
no login
end
wdrootz Tue, 07/31/2007 - 11:52
  • Bronze, 100 points or more
I think this problem only occurs when changing from Cisco IOS Release 12.2(18)SE to any other release. Please see your IOS Release.
