PIX515E: NAT one external IP to two internal machines
Jul 25th, 2007
Can you NAT External IP to two different Private IP's? Using a Pix515e version 6.3(4)
For example I want to direct smtp traffic on public ip address to a spam filter( but still want the mail server( to send mail outbound as that same public ip address.
schakra Wed, 07/25/2007 - 09:40
use static command
u can consider the below sample config
static (inside,internet) tcp 465 465 netmask
static (inside,internet) tcp 995 995 netmask
static (inside,internet) tcp smtp smtp netmask 255255.255.255
change the port according to ur spam filer uses & be sure that the public address is not included in your global list if any
Hope this wiil work & rate if it
