4506 to 6509 Blade compatibility
fmshea
We are going to purchase a 6509, how would I find out if the ws-x4306-gb1000base-x switching module in our 4506, will work in the 6509 ?
2 Accepted Solutions
Amit Singh
They all are compatible. The one way to check if the supported GBIC modules on both of the module on 4500 and 6500. They both support the same type of GBICs and if same GBICs are used at both the ends, they are compatible.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd802109ea.html
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet0900aecd801459a7.html
HTH,Please rate if it does.
-amit singh
Oops.... I am sorry I interpreted your question wrong. Nops these modules are not inter-changable. This module will not work on 6509. Cat4500 modules are only supported on 4500 series chassis and they cannot be used on a 6500 chassis. Both the chassis have different line cards and they are supported only on their respective series of chassis.
So in nutshell, 4500 switch modules cannot be used in 6500 switches and 6500 modules cannot be used in 4500 series switches.
I am sorry again for the wrong interpretation of the question.
HTH,
-amit singh
Amit Singh
-amit singh
Amit,
after studying both links, I am not sure you got my question.
I have a 6 port, ws-x4306-gb1000base-x the part number and photo is listed in the first link. So I am wondering if the entire daughter board itself will form fit into the 6500 chassis. The second link you provide shows an 8 port gbic daughter board. Seems like the 6500 is too wide??
Thanks again, Mike
HTH,
-amit singh
