CSS Multiple modules sharing CPU resources.
Good afternoon,
Maybe I miss understood, but I thought that If I had multiple modules wether it be a SCM or IOM module that the load would be spread across multiple modules?
If I keep checking the cpu resources, I see that only the SCM module has any CPU load on them.
RESNXLB01_C0302# sh system-resources cpu_summary
Chassis CPU Utilizations
Name Slot Sub CPU%
CSS5-SCM-2GE F0 1 1 33%
CSS5-IOM-2GE E0 2 1 0%
Name Slot Sub CPU%
CSS5-SCM-2GE F0 1 1 43%
Name Slot Sub CPU%
CSS5-SCM-2GE F0 1 1 29%
Thx
-Rich
Gilles Dufour Sun, 07/29/2007 - 23:25
  • Cisco Employee,
the traffic load is shared between the modules but only the SCM does all the maintenance function like CLI, Telnet, Routing Table,...
If your traffic is very low - less than 1% cpu required, you don't see any activity on the other module.
Do a 'flow stat' and verify your traffic rate on each module - FCB per seconds.
Gilles.
Gilles Dufour Mon, 07/30/2007 - 04:31
  • Cisco Employee,
Rich,
yes, the SCM is the only one managing the scripts and keepalives.
Gilles.
So is there any other way to accomplish the following service without utilizing a script? At a minimum presenting the web server with the host headder tag? Could something be done with a global keepalive?
service Marketplace-2
ip address x.x.x.x
keepalive port 80
redundant-index 8741
keepalive frequency 30
keepalive type script ap-kal-httptag "Marketplace2.company.com /keepalive/lb.htm Marketplace2"
active
Thx
-Rich
