Integration of Cisco Unity 4.0 with Cisco call Manager 4.1
Jul 25th, 2007
Hi to all,
i need a help friends..
i have installed cisco call manager 4.1 in MDS server.As such iam installing Cisco Unity 4.0 in another MDS server.
i got stuck while installing Unity software.This unity contians 13 CDs,out of that 1 is sql cd,1 is exchange cd,3 are unity application cds,others are drivers..
i dont know how to proceed further and how to integrate this Cisco Unity 4.0 version with Cisco Call Manager 4.1 version.
awaiting reply ...
shiv.
Overall Rating: 5 (1 ratings)
sivakumar.kvp Sun, 07/29/2007 - 09:03
hi,
it was very useful...going through.iam in begining stage of ccvp exam.can you help me by giving some idea/documents related to that of ccvp exam papers.
iam holding ccna right now.iam in confusion to choose my carrier in cisco carrier path.which one will be best in future among CCNP,CCVP and CCSP.
expecting suggestions regarding this..
--shiv.
AJAZ NAWAZ Sun, 07/29/2007 - 10:12
  • Silver, 250 points or more
It always helps learning about a topic or technology which will keep you interested. You'll achieve much higher standards like this. So, if you enjoy Voice then go down CCVP track. If you like security technologies - take the CCSP path. For general networking route/switch - it will be CCNP in this case. Make sure you have a solid foundation - then you can build whatever you like ontop of this and go all the way to CCIE.
hth
Ajaz
shikamarunara Wed, 07/25/2007 - 10:39
Shiv,
This book is good at explaining CallManager/Unity integration.
http://www.amazon.com/Configuring-CallManager-Unity-Step-Step/dp/1587051966/ref=pd_bbs_sr_1/104-5716703-5310356?ie=UTF8&s=books&qid=1185388652&sr=8-1
Also, the Cisco Unity installation guide has steps at the end of the document that will help you configure Unity integration. Between these two sources you should have what you need to complete the task.
-Shikamaru
Rob Huffman Sun, 07/29/2007 - 09:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Shiv,
You can't really go wrong with any of those three Career Paths. CCVP,CCNP and CCSP are all excellent choices. Have a look at the attached link (custom search towards the bottom of the page) there are 30 CCVP related docs/links.
http://ciscocert.custhelp.com/cgi-bin/ciscocert.cfg/php/enduser/std_alp.php?p_sid=85RKkQHi&p_lva=&p_li=&p_accessibility=0&p_page=1&p_cv=&p_pv=2.1288&p_prods=68%2C1288&p_cats=&p_hidden_prods=&prod_lvl1=68&prod_lvl2=1288&p_search_text=&p_new_search=1
Hope this helps! And best of luck with your studies.
Rob
